I have an old supply that a friend built for me, I should probably trouble shoot it, but need a quick band aid instead. Its a +/- 18v supply, the negative side is putting out little more than -19v. Can I just put a resistor in series with the output to drop the voltage? Seems like a 180K resistor will do the trick. The regulator is a 7918a, its for a pair of api 312's, current draw should be fairly low.
dave
dave
