roustabout
Member
- Joined
- May 3, 2015
- Messages
- 10
Hi, i need a replacement for a RCA BA-2C power transformer. Maybe someone does that before and knows where to find the right one...thanks a million, roustabout
roustabout said:Thanks but i can't find it, i've tried XT-3367...
Hi DMP. Could you suggest some transformers please. I'm about to start a build, looking into parts at the momentThe specs are on the schematic.
heater: 6.3v 1.2A
B+: 230v
Are you replacing the power transformer on a original vintage unit or are you building a clone?
If you are working with an original unit you should absolutely get the vintage one off ebay. You will not be able to find a different one that will fit & work properly.
If you are building a clone, I can suggest some transformers, as I built a BA-2 a couple years ago.
