Mendelt
I need to build a powersupply for some PM1000 line-amps (yeah i'm still messing around with pieces of my sawed up pm1000). They need 44V.
I was wondering if it was a good idea to use 7824's for this with a 20V zener to ground to regulate the voltage to 44V instead of 24V.
What is the max input/output differential voltage these regulators will take? I have some 2x25V toroids so if I use those I will have 70 volts max on the inputs of the regulators. This seems a bit high to me. But the nearest lower voltage toroids i can get are 2x18V and this is probably a bit low.
Another thing i can't find is what is the maximum power disipation of a TO220 component without a heatsink? When do i need to add one?
