Hi
I'm currently constructing a rackmodule around a vintage neumann v470 line amp. This module accepts both line/instrument signals via a input impedance switch.
I want to add a two preamps to the box as well, so i am planning on using the "5 dollar" circuit based on the TI ina217 chip -for simplicity and just to try it out. (http://www.ti.com/lit/ds/symlink/ina217.pdf)
So the question....the output of this mic preamp circuit is unbalanced. The neumann module input has transformers at the input and takes in a balanced signal according to the manual(can't get hold of the actual schematic, but the manual/specs is attached) Do i need an additional transformer(unbalanced to balanced) before feeding the signal to the line amp or can i just connect it directly in some way?
best
Lauritz
PS. Some people use the v470 as a preamp itself, but then you lose the flexibility of the 3 seperate output signals, which is very cool for parallel processing and signal splitting in generel.
best
Lauritz
