[Build] CAPI LC25-LC40, 500 Series Rotary Graphic EQ's, Official Support Thread
Some good news: Finished building an LC25 today and it turned out perfect. Sounds amazing. Still trying to track down where my volume boost problem with the lc40 is, is there anything other than some misplaced resistors that would cause the jump in volume?
You could inject signal into the good working LC25 and note measurements at the Test Points. Then do the same with the LC40 and report here where things stop being the same.
Anytime you are doing this we suggest a 400Hz sine wave. It can't be audio as the level would constantly be fluctuating.
Got it, forgive my ignorance but what am I measuring at the test points / what should I be setting my multimeter to?
So, I am curious, I have a pair of CAPI BT50's and a pair of API 550b's...is there anything that a combination of the LC25 and LC40 will give me that the BT50's and 550b's won't?
Im of the understanding that the LC series are surgical and useful for carving and sculpting frequencies as opposed to the broad and deep colouration of the 550 EQ's.
The LC's are not surgical. They are a 1 octave filter which is the same bandwidth as a BT50 or 550b. In some ways they are more flexible as you have control over 10 frequencies at once as opposed to the 3 or 4 of the others mentioned. I have had numerous folks tell me that they love running signal thru the LC's sometimes with no cut or boost just for the color of the module.
Ah ok, thanks for clearing that up, I am also rocking a pair of the CAPI VC528's. Absolutely loving them running into the BT50's. I was worried that a pair of either the LC25 or LC40 eq's would be overstepping what I already had. Even grabbing one of each for summing drum mixes is very tempting, I guess I just need to try them out!
Hey y‘all,
I screwed up my LC40 during the last assembly step (ofc).
I soldered the bypass switch the wrong way around, because apparently I am too stupid to read „flat“. So when trying to put on the front panel, it didn’t work.
So I had to de-solder the switch. But the new lead free solder melting point being so high and the switch using 5 solder points, I had to pretty much fry the PCB at 400celsius to desolder the switch.
The top center solder pin came of and took the metal lane of the PCB with it.
I managed to turn the Switch around and tried to solder it again, the loose top lane seems still attached.
The device turns on and passes through audio, but the Switch does not work and the device is „stuck“ on „Bypass“ (red Bypass glows), but flipping the switch doesn’t change anything.
So, how can I fix this? I am not located in the US and de-soldering the 10 expensive rotary switches is giving me headaches, so I would like to try to „repair“ the PCB.
Where do the pins of the bypass switch have to connect to via the PCB lanes?
I could try to solder thin wires to those points from the switch, as it seems the device is otherwise working fine.
Managed to get the switch to work correctly with some small wires.
LEDs now switch accordingly, but still no change in audio. I noticed that there was no „click“ from the relays so I checked the surrounding components and the 2N3904 H7 was soldered in the wrong way around.
Following that, I checked especially all ICs, but they seem to be correct.
Problem again, desoldering seems impossible on this PCB with my solder.
3 questions:
1. what values should the 3904 read when measuring it? I think using it the wrong way around shouldn’t damage it nor any components around it, but want to be sure.
2. where should the Pins of the 3904 connect to?
3. the 3904 reads H7 - if I want to order a replacement here, I can’t find H7 but usually H 331. it seems this just powers the relays so should be OK?
Thanks a lot!
3 questions:
Thanks a lot!
Sorry, I did not get a thread notification.
For Q1, Emitter goes to the bottom ground plane, Base to the junction of R6 & CR2 and the Collector to the anode of D4. Its just a relay driver so any compatible NPN will be fine.
