I'm building a pair of API 312 clones, and ran into an issue when setting the voltage for the discrete opamp (I'm setting it at +-16V for the Seventh Circle Audio SC-25). I set the voltage where I wanted it for the first preamp, then checked the second preamp. It initially shows the correct voltage, but then slowly starts to fall. I've checked for reversed capacitors, shorts, etc, and don't see any problems.
Any idea what could be causing this issue?
Craig
ps-posted this in the preamp forum, but nobody knew exactly what was causing the problem, so I'm posting here.
Craig
