shot
Hi all!
I got this beautiful Yamaha PM-430 mixer for dirt cheap. It's 8 channel mixer with Tamura xformers on input into TA-7136 opamps. Simple low/high shelf and two aux sends (pre and post).
I've tried it and it sounds very nice.
Except from cleaning faceplate, knobs, some isopropyl on pots, I plan to modify it for 8 channel recording.
The thing is that is very compact with it's own carrying case and it is perfect for me when going out of studio to record drums. That way I could finally avoid those uninteresting audio interface mic pres (at least first 8 of them).
I've attached excerpt from the schematic in this post so you can follow my train of thought.
1. Direct outs
Am I okay to assume that it would be enough to use impedance balancing here. For transformers there's no space and they would break out the bank in my case. I plan to tap off signal from the 10uF cap after the second opamp since at this point level seems good.
Is it okay to use 100R on signal to pin 2 and also 100R from pin3 to ground? Or should I go with lower resistor value?
2. Would it be enough to use SPST switch for EQ bypass? If I just leave EQ to be always on, but use this switch to bypass signal in parallel from one 10uF cap after first opamp to next 10uF cap after TR4/TR5? Or should I use DPDT to completely isolate EQ section (disconnect both input and output signal of the EQ)?
3. I plan on replacing TA7136 opamps on this input module. I was thinking NE5534... any other suggested opamps?
4. Any reason I should replace those five transistors? I went to cross reference them with BC550B and they might be similar. Does anyone know anything about those 2SC1681 ? Can they be the noisy part that I should ditch out? Candidates?
5. If I add phantom on input xlrs, I would probably mount additional DB25 connector to still have possibility to run line level signals into channels (because they distort lovely and could be useful in the mix situation). Is it enough to put 10uF BP cap on each hot and cold signal line to prevent phantom traveling along line input? Or should I use 47uF or higher? Bipolar or regular polarized lytic?
6. Of course, I plan to recap all the electrolytics. But should I also replace tantalum caps? Do they tend to age also? Remember that this is 1974 mixer...
And of course, feel free to throw other suggestions what to do!
I still haven't decided if I need output section. It's so tempting to disable it and use those six discrete opamps in a separate preamp build! Or at least take out four of them and leave two on the main mix bus to still retain mixing capability.
Sorry for bombarding with too many questions in one post!
Luka
1. Direct outs
Luka
