Dimitree
- Joined
- Jul 26, 2011
- Messages
- 131
I'm using this circuit to provide a mixing section and headphone output interface to my a digital synthesizer that I designed (that runs at 5V DC).
I basically copied this circuit from my Korg Volca synthesizers, all those little machines have this circuit on the output, and found it handy since the supply voltage is the same as mine.
The only modification I did was to increase the gain. The original has unity gain achieved by 22K resistors.
I needed more gain so I changed those resistors. But now I got loud oscillation (around 4KHz) and a noticeable distortion when using a mono cable connecting this output to my line input interface. When using the headphones it sounds fine.
I'm not an expert by any means, so I just guess that, by grounding the ring on the headphone jack when using a mono cable, the shorted channels draws too much power from the opamp and make the other channel distort and oscillate. Is that right?
If so, is there any workaround? Or what could be the issue?
I tried to replace L3/L4 with 100R, the oscillation disappeared but the level when using headphones was dramatically reduced.
So I tried to move the 100R inside the feedback path of the opamp, but that didn't fix the oscillation.
The chip that I'm using is the TPA6111A2
Any suggestion? thank you really much, and sorry for any obvious mistake.
