bxt403
Greetings,
I've had a Presonus MP20 (early version that already has a Jensen trafos installed) for about a year now.
I contacted Presonus support to see if they might help with mod , and they told me to :-* their a$$ (actually, I was told that if I had any problems with my unit, I have to ship it to them for repair and user mods are a big no no).
I installed AD797's since the consensus on the web seems to be that they're the best suited for a Jensen Twin Servo (not to mention the schematic for an IC twin servo pre on the Jensen website also shows AD797s in it). I figure since the MP20 is a "twin servo mic preamp" the Jensen schemo is identical (or at least very similar) to the MP20 cct. I managed to adjust the rails to +/-18V on the power supply on my own.
The only problem I'm having now is that there is a tiny square pot (looks like a lego block) on each pre channel that seems to adjust the LED meter's response or perhaps locking of the servo (since the signal seems to degrade I'm thinking it's a combination of the two). I'm not sure how it should be metering (ie: are the red/clip led's indicative of clipping at the input or the output?). Adjusting the gain knob also changes the level of the LED meter so the logic follows that when I feed a test tone into the unit I should calibrate the LEDs to the amplitude of the signal I'm putting in or does the gain setting need to be put into account? Should I calibrate and set the LED meter's to an external converter input?
All help is appreciated.
Thanks.
