I solved the hum issue from the previous post, thanks to some advices. It's practically hum free now, even at the max volume. Some hum still coming from the reverb, but it doesn't bother me.
But there is still couple of nasty things going on:
When I adjust the volume pot, it makes a scratchy click sound. I've noticed that if I go slowly, there is no clicking - but if you change it fast enough you can clearly hear it. I suppose it's not the pot, otherwise the speed would not matter?
Also, when the amp is pushed into distortion, it makes nasty scratchy sounds. Not always, but half of the time.
I suspect these problems are related.
I tried swapping preamp tube, but the problem is still there.
Does it ring any bells?
