MrShhh
Hi there,
I've set up a simple balanced input stage with 12 position switchable gain trim (range -6dB to -11.5dB)
The gain is controlled by swiching R3 & R4 with a dual gang rotary MBB switch. R3 & R4 are carefully matched to preserve the CMRR.
I'm having trouble with the switch crackling and popping randomly, sometimes it's silent and sometimes it produces loud clicks. This only happens when the stage is passing audio.
Is this a problem with DC building up on C1, C2 or C3? Or something else?
I don't fully understand what might be happening here, it's the first time I've encountered this problem. I'd be grateful if someone could point me in the right direction. Thank you!
