Good morning, Anyone here more familiar with LC based VCO clock circuits ? I've finally got this Roland SDE2000 unit up and running after numerous issues and now the only thing that is left is the VCO calibration for the sampling clock. Adjustment is via tuning L1 however turning L1 clockwise at almost one end stop of the coil I get too quick a pulse and the remaining 85% of the coil there is no clock at all. No adjustment range. I was of the understanding that clockwise was increasing the inductance which should reduce the resonant freq but the clock speeds up. I'm kinda assuming that the coil is OK as it does have some adjustment but only a very small amount right at one end and certainly nothing in the middle ? The transistors, diodes, KV1 and tants all seem ok. A replacement coil is proving impossible to source (to test) as its a 7.5mm mini sized one. I'm not sure if it is the coil or something else. Is it possible that either any of the DC blocking caps could be causing this coil adjustment issue. or is there a way to reduce the resonant frequency clockspeed by changing/adding either capacitance or inductance somewhere else in the circuit? Essentially the unit is overclocking, so it has an extra 100ms (ish) of delay sampling time (yay) but it isnt happy as it drops out and distorts when in this region (not yay). Any thoughts from someone would be greatly appreciated.
