Prophet 5 Rev 3 All Lights Illuminated No Sound
dr_ew
Member
CA
When I power on my Prophet every light turns on immediately instead of going into the Tune routine.
I'm trying to get a scope to test the CPU and clock, but i'm wondering if there is anything to try in the meantime to bring my Prophet back to life.
From the service manual it says this about troubleshooting:
"The general procedure is to first remove socketed PCB 3 devices: CPU, EPROM, SPAD RAM, and NV RAM-WHICH WILL CLEAR THE PROGRAM MEMORY!"
Does this mean to power off, pull a device, reinstall, power on?
+1. I'm pretty certain they do mean reseat the socketed devices with the power off, like you said.
Edit: welcome to the forum. Best around!
Yes they definitely mean to remove and reinstall with the power off, but i was just wondering if somewhere in the procedure the power is turned on with the device removed.
Not 100% on this particular synth, but I've wrenched on a bunch (biggest project in terms of time was a Memorymoog) and I've not yet run across that. I would suspect not, but I understand how that could be intimated from the text :)
Edit: it could very well be remove the devices and then test for shorts. Hopefully someone will chime in who's done this in the past.
https://elektrotanya.com/sequential_prophet-5_sm.pdf/download.html#dl
Page 134 there seems to have the pretty straightforward schematic of the power supply (a handful of linear regulators).
+5V being 8 (instead of 5.6V or so, -5 being -28(!!!) and -12 being 28 points to some shorted-through 7805 / 7905 / 78(M)12.
There's no saying whether the circuitry they were powering, managed to survive such overvoltages though... 😬 🙈
Any idea what could cause all of the voltage regulators on the power supply to short and stay shorted?
It's not "all the regulators" - as you've established, the +/-15V are fine, right? And, well, semiconductors tend to stay shorted, once they burn / get zapped, so i'm not too sure why one might expect them to "come back" for any reason...
78xx / LM340 seem to have a max input voltage of 35V; the 317/337 may well be a bit more rugged in that respect. The unit's mains input might've been switched to 115V and plugged into 230V mains, perhaps?
What's the history of this device? Did it just randomly suddenly conk out one day, seemingly out of the blue?
Need to get the regulator voltages right first -- with main circuitry disconnected. I'd swap out +5, -5 and the 12V (three components, not expensive). Then assess any further possible damage .
Visual inspection:
Do any components on the board look burnt? Maybe also sniff when board is cold -- meaning definitely NOT when powered.
Do components on the board measure plausible on a DMM when unit is NOT turned on:
- diode tester on diodes and across IC pins
- all resistors give (some) reading
- also, I've come across shorted capacitors on power rails on older PCBs -- much to my surprise. Test for connectivity across leads.
Good luck !
