Aleguitarpro
Hi.
I need to build a PSU for 2 SSL 502 EQ modules.
I've several 15-0-15 transformers and I think it's enough to have a dual 18Vcc rails (15x1,41= 21,15 for rail so enough for a 78/79-18 regulators).
So, the dual rail with a 7818 and a 7918 it'is not a problem.
I think to get the -24Vcc with a doubler and a LM337.
Please, could someone check this schematic because I've all the correct voltage but after a few seconds the positive 18 rails starts to lowering his voltage and C3 and C4 became very very warm...
I haven't found any reference about the use of a doubler with a negative rail but maybe there's an error in the use of the positive rail of the doubler as ground.
Thanks for help.
A.
Thanks for help.
A.
