Hello to everyone! This is my first post here even if I'm reading the forum since a while now! Thanks again for accepting me.
I'm here for asking some advice on what to do with a Studio Master pro-line 16-4-8 I received as pay for a work.
The owner pointed out 2 channels that actually wasn't working, but as everything was working properly i decided to clean it up deeply all, and most everything was working smoothly......
But the day I decided to stress him out a bit a fatal error occurred.. I forgot a cloth directly on the back of the device, where the transformer sit... and it blow up. I really suspect an overeating of the transformer as the toroidal has been shorted and I guess there is no way to fix it (or better, where to find the substitute for the toroidal in germany).
Does anybody think this is a reasonable explanation or should i suspect something more? I was as reparation technician for audio devices but never worked on the part of this circuit.... I mostly work with DC voltages
Reading this forum I found two solutions:
recording.org/index.php?threads/vintage-mixing-console-needs-power-supply-help.52650/
https://groupdiy.com/threads/diy-console-power-supply-which-one-to-choose.52316/page-2
Would be possible building a suitable +-15V PSU out of two of this like it was realized in the second post? would be actually the cheapest solution for me.....
In that case, would just be necessary to wire the +15,-15 and ground directly to the mixer or should i create some kind of protection for the lines first? I could follow the schematics i found.....
MW IRM-60-15ST - Switching Power Supplies Module, 60 W 15 V / 4 A, screw
The soultion of the first post is a bit too expensive for me, would be 200€ more or less... could someone suggest something similar, maybe cheaper?
Please if someone have some hints..... I'm not totally noob about electronics , but pretty new into PSU and things that can actually kill me or damage my house seriously XD
Thanks to everyone that will help!
