Psu for v danner modus v367 v467 v567
Drea
Berlin
Ola members,
I wanna make a 1 strip power unit. For use for a ribbon mik .
Is it possible to get the 24 v with 2 transformers of 12 v on both sides.
What means pin 9 11 and 13 ?
    922 KB
9 and 12 are outputs
to 13 you connect a switch
Räuspertaste means something like "clearing throat button"
my guess is it mutes the output momentarily when pressed .
why would you use 2 transformers ? ( i guess cause you got them )
but you loose space and weight might be an issue .
you need some kind of voltage regulation anyway
“you need some kind of voltage regulation anyway”
Than I purchase a cheap 24v option.
Thanks for your answer.
Btw what means 15c GEH.
Is there a difference?
There is a difference. The Haufe transformer is a expensive quality product designed for audio use. The mumetal shielding allows you to build much more compact and you will have fewer problems with magnetic interference.
