scott2000
that could result in (or contribute to) the secondary voltages being lower than expected.
And the PT itself. Which one is being used? I have missed it.
I'll have a look at it in PSUD, thanks for the suggestions.Or put the circuit in PSUD and re-jig it. The info from the Hammond spec sheet tells you the DCR of the windings so you have enough info for that. Your load is 17 - 18mA so put that in at the junction where C5, C9, R13, & R14 meet. No need to include R13, & R14 and their associated subsequent caps in the PSUD schematic for now.
Caveat: Looks like the largest cap value you can use as the first reservoir cap after the 6X4 is 40uF. However, you'd probably get away with using a 47uF in this circuit. But don't go bigger in that spot.
Cap values downstream from the 6X4 can be larger in value so your C5 & C9 in parallel would be OK.
Although I couldn't see the whole waveform at once, I was able to see the peaks on my scope by moving the trace. I could see clipping, although not the voltage at which it occured. It looked like the waveform on the right:Again I think the secondary voltage should be checked with an oscilloscoe.
The simulation I made shows tha tmainly because of the DCR of tehe HT secondary, the sinewave is drastically clipped at about 260-270V.
Of course a xfmr with a lower DCR would probably help.So my question is, what can I do to fix this issue? Would a different power transformer solve the problem?
A choke is also a possibility, but solutions are costly, much more than shorting a resistors. And what do you care if your B+ is a little low? Do you want +24 into 600r?Another possibility is that there is a note on the PCB indicating that resistor "A" between the big caps can be replaced with a 10H choke.
It would be very nice…Do you want +24 into 600r?
That's the value I entered in my simulation, 177 ohms each side, along with 40 ohms for the whole primary.I found the typical DCR on the spec sheet, HT secondary is 354.4 Ohm +/- 20%
I didn't use PSUD (I hate the HUI); I made it with LTspice.I worked out the specs for PSUD as best I could, and when I ran the sim I got an error message (attached). The sim was set to begin after 17s, so the 6X4 was quickly overloaded. Is this the source of the clipping you found Abbey?
