Between moving the interstage and the output transformers i can get the hum down to -80db from -60db.
I'd consider -80db a victory. You may not get it much better than that even with potted iron. I built my pair of Pultecs with an external supply to avoid what you're going through now.
If you get out on a limb with the IS and OT mounting, you can try rotating the PT 90 deg. With PT there's usually one side that radiates higher than the other and it may make it easier to find null positions for the other iron.
