Hello,
I'm trying to repair a pultec EQH-2. It works well for a couple of hours and after It starts to make some pop,crackle and other noises...and I have the same problem when the pultec is in bypass position. The 6X4 tube that is the rectifier tube (If I well understand) is ok, then I changed the two 22UF/450V caps, but nothing has changed....
I'm searching for a schematic and/or any helpfull information.
Thank you
Fabien
Thank you
Fabien
