i'd like to add a mid section to my PQD2, in a separate unit, and i wondered how I might go about joining the 2 together, i was thinking that rather than connect the output of PQD2 filter board to the io/power board, i might be able to connect it to the MeQ filter board, and then connect the mid section to the io/power board of the PQD2
...or is there more to it than that? I'd like to avoid having to buy a whole new set of LL4502's and power supply if possible, but i don't mind fiddling with a few resistors if necessary, has anyone done this?
anything thing i should take into consideration? has anyone done this before?
I actually only want a single band of Mid, although 2 would of course be more useful, actually i only want to add 700Hz, 1Khz, 1.2Kz and 1.5Khz (and with a smaller range of Atten/Boost settings)
