nwsoundman
Here are a couple pics of a quad eight thing I am building. It is two EQ 333c's and two CA-137 line amps. The wiring is temp so I can use it while I wait to build some proper relay switched bypasses, pad, phantom, etc. As it sits you can fully bypass the pre's or eq's from the front panel. The input trafos are UTC o-8 run backwards. No noise and lots of tonal choices. You can turn the pre all the way down and boost the gain on the eq for some AM-10 sound or turn the eq gain way down and turn the pre up more than normal. Both amp types sound great. Still need to find some bulbs to light the meters.
http://home.earthlink.net/~nwsoundman/id13.html
