I have 2 Yamaha pm-400 mixers, nice little discrete guy full of transformers apparently used by the stones live for bass or something in the 70s/80s schematic is attached. I noticed when switched to line in the signal goes thru the mic input transformer straight to the 10k monitor pot into the bax EQ.
I have plenty of 10k:10k transformers and was wondering if I could possibly use them here, so line in would bypass the mic transformer and go straight to a 10k transformer with the 10k monitor pot on the secondary or would I need some different kinda termination for the transformer also thinking if I can work that out also using the transfer as an interstage between the mic pre and EQ when using the mic input or DI (which I have on a switching jack between mic xformer and mic pre)
Also I'll possibly find a way to use the output amps from my other pm-400 to drive some more transformers for direct out options for each channel
