NOON
I've seen plenty of discussions about creating a 'virtual 0V' at the midpoint for a single-rail power supply, e.g. turning a 48V rail into a +/- 24V equivalent.
What I haven't seen is much, if any, discussion on the best way of splitting a floating power supply, e.g. switchmode. I'm looking at using one of the Meanwell 36V supplies split to +/- 18V for a preamp project and have ended up a bit confused about analysing possible 0V currents etc.
Methods I've commonly seen for splitting rails are :
1- simple resistive divider, commonly only seen in guitar pedals etc
2- opamp buffered divider for better stability / lower impedance
3- variations on this using power opamps or more complex splitters to drive the opamp buffer, including dedicated 'reference' chips
4- discrete circuits like the 'Sijosae' circuit commonly used in battery powered heaphone circuits.
Any opinions on the relative merits or otherwise of these circuits for a mic preamp application with switchmode PSU? I'm leaning towards the discrete option, but would it be overkill for relatively small preamp currents?
Also, best point to connect Chassis Earth / external 0V to the circuit.
