thomasdf
Ok, so I need to switch the comp in pos 4 or 5 and ajust these is order to have the less amount of control voltage (so DC? ) in the audio path..?
Anyway, I will recap it prior to keep working on it.
I'll also take some time to redraw the schematics as I realise it may contain some mistakes, and is not convenient to read at all. Way less convenient than the pixel version I have of the original one. I'll redraw it and will add the correct values..
I'll also have to build a proper power supply!
Here are the tubes power requirement:
6K4P:
250VDC @ 5,5mA
6,3V @ 330mA
Datasheet: http://www.r-type.org/pdfs/6k4p.pdf
Right now they are replaced by a pair of EF93 (drop in replacement, but maybe I am wrong? )
EF93:
250VDC @ 4,2mA
6,3V @ ? mA
Datasheet : http://www.r-type.org/pdfs/ef93.pdf
6N3P:
150VDC @ ? mA (can't quite figure it out from the datasheet?)
6,3V @ 385mA
Datasheet: http://www.r-type.org/pdfs/6N3P.pdf
When I have figured out the missing values, I guess the ideal PSU will be 250VDC and 6,3VAC. I'll need to add the power consumption for each tube and that will give me the minimum amount of mA the PSU will have to deliver.
Am I correct so far?
Sorry if dumb questions, I have never designed PSUs for tube circuits... I know there is also a load that I will have to calculate in order to figure out the voltage drop of the PSU.
6K4P:
250VDC @ 5,5mA
6,3V @ 330mA
EF93:
250VDC @ 4,2mA
6,3V @ ? mA
6N3P:
6,3V @ 385mA
