CJ
Nice work!
What kind if AC voltages does that inner stage PRI see at normal operating levels?
Sowter probably uses an EI core with a larger cross section , this means less turns needed to get the equivalent Henrys as the original . Less turns means less effect from DC imbalance as the H field for DC is a function of Ampere Turns.
