buildafriend said:I was on the phone with Cinemag selecting an output transformer for this BA-2. Dave was nice enough to look at the schematic and said:
"Hi Jon;
I think that you can live with a turns ratio of 4:1. The CM-2810 with steel laminations and butt-stacked should work well. $40.55 If you know how much dc current it will take, that can help me figure out the amount of gap it needs.
-David"
Should I assume that the DC current that the the OP transformer will be taking is the exact amount that the PSU is dishing out? 250-300V DC.
Interesting. Thanks for the great info. With a different PT the situation may be different? I'm using Antec, http://www.antekinc.com/details.php?p=670. The spec sheet does not give DCR but I could measure it.The datasheet for 6X5 indicates a 4uF head capacitor. The RCA choice of using 40uF is justified by the fact that it runs at 2/3 of the rated voltage and that the transformer has 700 ohms DCR for each half-secondary. I bet you could fit a 47uF without further ado, but, as always, there's the risk of optimism, so you could use a 33uF. Remember that very often, elcap values were overrated because designers knew that the value would decrease with age. Today, elcaps are much more stable, so your 33uF will be equivalent to a 5 years old 40uF of period technology. And anyway, you're free to compensate the relatively feeble value by incresing the other caps that follow. C4=33uF and C5=C6=47uF should be adequate.
"Hi Jon;
-David"
SCHEMATIC http://www.coutant.org/ba2c/index.html
That is a good idea; that will give you one more parameter. If the DCR is lower than 700r, you may want to introduce a series resistor to limit the inrush current.dmp said:The spec sheet does not give DCR but I could measure it.
It is really a transformer-coupled output...As this is an inductance coupled output stage (correct?)
...as such, it doesn't have the benefit that inductor-coupled stages have, because the ripple voltage (that would be somewhat filtered in an inductor coupled stage) is integrally reflected at the secondary.I'd think the rejection of power supply noise might be better than resistance coupled???
True, but you have to take into account the reflected load impedance, which appears in parallels with Rp, so you end up with a significantly lower value, typically about half.lassoharp said:A 6C5 looks closer to 14K. That calls for a hefty L to stay "flat" to 30Hz in a no NFB circuit.
The answer is simple in its formulation; the inductance with DC flowing must be consistent with the Rp/Rload calculation.When David says "It will take X amount of current", I'm not sure if he means the amount of current it can take with no loss of L, negligible loss of L?, or what.
Simple answer, but in practice, there are several answers; you can't expect the mfgr to publish the whole family of curves L vs. DC current vs. signal amplitude vs. frequency.Either way I think we need a measured L figure for the pri to see where we will stand.
That's what one ends up doing in practice; it is somewhat less fulfilling, but OTOH, that's what happens when you select a product in a catalogue, as opposed to designing one from scratch.So, I'd ask specifically for that and maybe mention a source impedance figure (the plate resistances I mentioned above).
Now, you're completely spoiling the game!Or, stated another way, you want response within say 0.5 db to 30Hz with a given source Z @ 4ma unbal DC. 4:1 seems to work fine. That's an A-25, which is what myself and some others have used.
Yes; that's as simple as that: as soon as DC hits the xfmr, the inductance decreases. How much and how rapidly depends on several choices, typically the nature of the core material and the influence of the air gap. Each mfgr has its own receipe, and even for the same xfmr model, there could be differences, because the actual air gap depends on the pressure with which the core is assembled, each lamination is different from another, and so on.lassoharp said:meaning as long as the L doesn't start to fall due to the effects of unbal current?The answer is simple in its formulation; the inductance with DC flowing must be consistent with the Rp/Rload calculation.
Because of all these variable parameters, the xfmr designer must apply a worst case factor, so an average xfmr should be better than specs in most cases. The concept is that the worst combination of tolerances should still result in a usable xfmr.The limits of the transformer design?
That's exactly what it is. The problem is that L varies with DC mag, with signal amplitude, and to a lesser amount with frequency, in a manner than can hardly be described with simple linear equations, so the designer will make his design work within limits that he has to define - hopefully these limits will be corresponding to a desirable configuration.Without the effects of unbal DC, I'm understanding it as mainly a matter of source impedance vs L for estimating the low freq characteristics. And at some point the effects of DC start causing the L to fall
Yes, and, as emrr says, it is not a brutal transition, it is a continuous but non linear behaviour. I can estimate that the same xfmr, with only 2mA, would go down to about 30Hz at the same reference level.- I guess a good example would be the UTC A-25 -15K:600, rated as "flat" to 40Hz with an allowable unbal DC of up to 8ma. Is it correct to interpret this as: assuming a source impedance of roughly half the pri, you will have sufficient L to get "flat" to 40Hz for any value of unbal DC up to 8ma? And plot your own demise once you exceed the 8ma?
EvLoutonian said:Cool to see this project ..
I just picked up an AWA BUC-1 console, which is almost identical to the RCA BC-2B.
(I believe AWA had a licensing deal with RCA, to produce, assemble, or replicate some designs from RCA, for the Australian broadcast industry here in the 1950's etc).
So this console has three of the dual pre-amp modules .. . Nice to find some reference material out there, as this thing is gonna need some restoration.. I just hop all the transformers are OK!
emrr said:Those RCA preamp outputs are notoriously bad when in a console; I'd say 33% on average I've encountered.
