natrecstudio
Member
- Joined
- May 4, 2013
- Messages
- 16
My BC-3c is passing clean signal on all channels, and the Audition bus (which is only available via the built in power amp) sounds great, but the Program bus (which is the output to the real world) sounds dramatically thinner than the source signal even though the associated board's voltages were checked, and that board (as well as virtually everything else) has been recapped.
The line inputs were at some point modded with UTC transformers and Daven trimpots internally, but the behavior is the same on the mic channels, and as I say, everything sounds correct on the Audition bus, so I'm not suspecting this is an issue.
I would so appreciate any input as to what you'd consider first in trying to track this down..... so close, and yet so far!
Thanks!!
Danny
Thanks!!
Danny
