Re-Capping Altec 1567a
templemark
Hello.
I am in the process of recapping my Altec 1567a to hopefully remove some of the noise.
I replaced which I think are the main signal path Caps with Orange Drops and MojoTone. (See attached) This cleaned things up somewhat, but still noticing noise.  (The noise is somewhat non-linear. It comes and goes unevenly at various input/output gain settings and can vary from buzzing to more white noise-ish.)
Should I go after any other caps also? EQ circuit? Power Supply?
Advice is appreciated. Thanks!
This is generally not a cap problem.  If you are doing caps, you should do PSU for sure.
Some amount of noise is expected given 97dB gain.  You are probably hearing a combination of tube noise with carbon resistor noise.
Ok thanks I will try the Power Supply Caps next. (more important before or after the ceramic caps on the EQ?)
This noise is still pretty loud at around 40-60 db range.  I can try different tubes to see if that is part of the problem too. Its around 10x more noise than my LA-610mkii tube pre.
