Reamping box question transformer question
luis
Portugal
I need to reamp some tracks.
Can i use an api2503L for a reampbox? can you give-me a direction on how to wire them, if they are usable?
Thank you,
Luis
not at all ideal with a 2503 but the attached circuit should work for you.
the potentiometer is optional.
    209.1 KB
Hello Luis,
like  gridcurrent said it's the 2503 would not be the ideal transformer for a reamp.
I think you would be better in using that transformer in a API Mic Pre style output.
there's nice an affordable options as far as reamps go.
If you live near Lisbon, I have some Neutrik and Edcor transformers for reamp boxes, I bought a few for myself I wouldnt mind help you out.
here is a reamp schematic using an affordable Neutrik NTE 10/3 transformer:
    123.4 KB
pics of different Neutrik Reamp builds:
neutrik%20transformer%20in%20the%20german%20sound%20and%20recording%20magazine2_2.jpg
Hey Whoops nice builds you have!
I live near from Lisboa, in ericeira.
The reason i asked about  using the api 2503 is just because i have them laying around, for another projects,  and i tought that maybe they could be used temporarily for this purpose.
I hear good things about the edcor transformers for reamping if you have a spare one, i buy!
I definitely have .
Pm me
Hello Luis,
Thanks for sharing this design. Im also building a passive reamp over the Neutrik 10/3 transformer, but a simpler one.
I had few questions about this design.
- The 10k resistors at Input do increase the impedance inot proper level?
- When would I need the impedance pot for the input? Can this be left out?
- Why is there a 1n cap (c2) between the volume pot lugs. Im thinking to leave the TONE and output VOL out compeletely.
I think R1, R2 and R3 are there to form an attenuation PAD for the input signal, so that the input voltage is reduced
The impedance pot changes the load impedance of the input, it acts as an extra tone control, I have it in my units and I like it.
You can for sure leave it out if you want
I think that that CAP is a treble bleed, it's there so that when you reduce the volume you don't reduce the high end frequencies also
I have a schematic of the same circuit without the pots, I will search for it in case you want to do it simpler
here it is the circuit without the pots
I also have the complete original article on this Reamp, it explains how it works, if you are interested in the article PM me your email
