.I have just finished a -tedious turret board- built Redd 47 -not dissimilar to the La2A layout, that 'photographs extremely well', but using this 460 volt transformer with a 6.3 volt secondary, fails to supply 6.3-7. volts to 'Two' tubes', namely, the E88cc and the EF86. I have 2.5 amps of current available, but have not been able to reconcile how to terminate- this' often 'overlooked topic. I build Microphone systems with OB2's that sound better than Neumann.. but when it comes to providing "AC" 6.3 voltage to -two 'differing tubes' such as is found on the REDD 4 7, I can only get 3.5 volts on both. I have only done DC discreet choke fed shunt regulation for filament and have no experience in AC heater design with different tubes. 1. First attempt - simple parallel- ( load to pin 4 and 5- both tubes..)no ground ref.. gave me a steadily changing '5-7volt' on the E88cc and '4- 5.1 volts' on the EF86(receiving current last..). 2. Second shot, I changed to the Guitar Amp approach where you short 4 to 5 and then use "9" on the E88cc as the other terminal.. with the same on the EF86- except using pin "7". 3. Third attempt, I -now have 3.5 volts --across load , with E88cc pins 4 and 5 tied together, other lead to "9" , with the EF86 simply going to pins 4 and 5- however with a ground reference.There is no center tap, so I built out two 5 watt Ohmite resistors to signal ground and took my 7 volts from there. Also, can I not 'clamp' this with some simple voltage clamp at 6 volts? Across the load?..The transformer is "6K49VG" Hammond(La2A) and is capable- more so than I (ha..) with a 460 volt secondary @50ma/[email protected] WITH CT for B+. I have great B+ voltage at 294volts and I'm using an AMI Tab Funkenwerk BV8r at .6.5:1 for input and output- since they are around.. Input secondary load resistor is 63k. Output is 10k over secondary. Any help with this Multiple Tube AC Heater dilemma would be appreciated!
