Not sure yet, I've started drawing this PCB just as an exercise, but now, when more transformer options have been posted, I feel tempted to try it. If there are enough people interested to make a pcb run in reasonable prices(around 10pcs at least I guess) then I can order some.
Edit:
Changed ecc88 plate resistor for a 5W one, moved cathode cap further away from the tube. 240R resistor should be mounted on the gain pot's legs and wired with shielded wire to leftmost two ins in the X1 terminal. Do whatever steps you want with the gain switch and hook it up with shielded wire to rightmost part of X1. I'll look into PSU now.
Edit:
