Deepdark
Hi there
I posted it on the upgraded site, but it has dissapear. Anyway, here it is. I've build a Redd47, turret board. Integral to the original schematic exept for the psu, I made a RC filter made of 5 stages.
R11/8k2 is getting hot. First, it was a 5W ww, and it started to smoke once I turn the unit on. weird. I then tested all voltages, all spot on. Then, I measured vdrop everywhere, spot on again. Then, i inspect the layout for anormalities, mistakes, resistors and caps values, everything looks good. Looks after all caps to be sure there was no dc, and it's ok. So no caps leakage. I changed the tubes, changed nothing. I then measured current, again, spot on everywhere. Then, I changed teh 5w 8k2 for a 10w. It does not smoke, but remains quiet hot. I tested the unit and sounds good.
So here we are. I've been told it was due to the class A output being hot. I know Class A can get quiet hot (just like my octopre here in my studio). I've been told also that the output stage of the redd47 is hot, due to the hight current/power consumed here. Total power 6.6-7.0W, and probably the majority of it comes from the output, so maybe it's just normal and I'm overthinking here.
Attached is the schematic with my readings
