Winetree said:
Thanks for the reply.
Also having trouble trying to figure out layout in Dan's Mike P.S. case. Board on side, tube hits O.P. trans, etc.
E-mailed Dan asking if I could buy 2 of his Extra wide & long cases he uses for his D.I. Didn't get a reply.
Yes, using Garash Labs board and transformer. I don't have the power transformer yet.
Which one do you have? Thinking about the Edcor.
https://edcorusa.com/xpwr191
yeah, i had to mount the pcb on a couple 4" zinc L brackets, with the bottom trimmed to about 1" long and drilled to fit along the left wall, if you were looking at the xlr side of the psu case. i can fit everything inside in this configuration, all neat and tidy 8). are you using the Garash Labs output tx?
It all fits, however i have a hum. and the thing is, it's not even that bad, but enough for me to want to do something about it.
the hum subsides when taking the power transformer a few centimeters outside the case. so that's my problem with the CC psu case. i'm using this power tx:
http://www.toroidal-transformer.com/shop/high-end-audio/power-transformers/314/2n465-powertransformer-for-tube-amps---44va-.html#.VGwPbVfF95U
kind of pricey, but it was the only off-the-shelf toroidal tx i could find that matched the specs of the circuit perfectly. in retrospect i probably would have looked a bit harder for something comparable, or tried a similarly spec'd, but not perfect, toroidal tx. the reason why i went with a toroidal power tx is that they give off less magnetic flux, making them perform better in closer proximity to the audio circuit, output tx. in retrospect i might have tried a power tx like the edcor you mention, maybe some mumetal shielding for it, and the hammond 1402FV or hammond 518-0910 case. unless mumetal shielding stops my hum in the Collective Cases enclosure, i'll be moving it to a hammond 1402fv, which will give me plenty of extra space, but in a similarly portable enclosure. i bought both cases at the same time, as i anticipated this dilemma and wanted a speedy workaround. i just think the CC case is very nice looking
but i dont want to sacrifice noise for aesthetic, so if i cant stop da hum, i'm moving on.
ultimately you just have to try it out, as Abbey suggested earlier in the thread. i always think that going with the best bet for low noise(thus my toroid) would be the way to go, but it depends on the enclosure and how tight and tidy your wiring is and the exact position of both transformers and the pcb. totally guesswork, to a point, unless you have a way to measure gauss
but easily figured out with minimal parts exchanges.
i'll let you know how the shield for my toroid improves(or not) the hum, it might be worth the extra $ to have such a small and nice looking enclosure(or not depending on if you mind ;D)
