I made mine with AC heaters. I have some hum issues but think they're related to the proximity of the power transformer.mp5hkm said:any reason i couldn’t power the heater using a 6.3v tap instead of converting it to DC?
AZ999 said:It is impossible to give good reply with so little information about power supply used.
Bridge or separate diodes for a few mA at ~200Vdc (HT) as used in this DI shouldn't get hot. In many other similar projects they are at around ambient temperature.
If you regulated heater then 1N5822 diodes can perform better because they don't get hot at those currents, low drop regulators as LM1084 instead LM317 also work well because they don't need big heatsink. Such changes are not really necesary with properly chosed psu transformer.
I don't know where alleged 47u capacitor is, value for HT should be more like 470uF and 4700uF for heaters. If you could touch it and circuit works properly then heat probably comes from very hot diodes or whatever is close to it. If you followed shcematic some heat is ok, components which can be touched often aren't too hot, so don't replace what works.
Be careful around power supply because currents there can be lethal!!!
If your layout is really tight, is it getting warm from a nearby resistor? What is your DC voltage post rectifier? Check at first power on (before it settles) and after being on for 20 seconds.mp5hkm said:Finally got around to building this guy. It sounds absolutely wonderful and has NO noise whatsoever but the 47uf capacitor after the bridge is getting pretty hot. (doesnt burn me and im able to leave my finger on it)
Just wondering if this is normal?
Also not sure how hot the bridges are suppose to get. They definitely get warm.
Currently getting 175v on plates, and 6.3v on heaters.
using 220 ohm resistor on each cathode and bypassing with 470uf cap.
andyfromdenver said:If your layout is really tight, is it getting warm from a nearby resistor? What is your DC voltage post rectifier? Check at first power on (before it settles) and after being on for 20 seconds.
You're probably fine. Congrats on an awesome DI. I posted my two tube eq version in my sig.
If it's your first tube project, please be careful touching anything in there.
Andrew
andyfromdenver said:Looks like a tweed bassman chassis, cool. That's nice for putting lots of space between the power and output transformer.
I think it will be hard to check some voltages on the perf board, so as long as it's not melting, maybe just box it up and have fun!
If you'll permit my advice/ opinion (which may vary from the experts) I would construct a future one on a turret/ eyelet board or using tag strips, for sturdy-ness. Not to mention it's a nice low parts count project for point to point wiring. Keep in mind an end user, you may sell this on, and you know how musicians can really knock their gear around.
I was making these boxes for people a while ago and Drive by Truckers bought two for their live show. I had constructed it with the tube sitting outside the chassis with a tube cover, and oh man, after one year, I had to really beef it up, it was kind of frightening, actually. Since then, they made a custom travel case for it. I've since determined it is worth the hunt for a good/ big chassis to keep the tube inside.
Andrew
mp5hkm said:
yvus said:Hello guys, and thank you for this great thread.
I am looking for the output tansformers used in this project, do you have any idea where I could find fitting ones ? is CJ still making them ?
Thanks !
