Regulated B+ ?
Delta Sigma
GDIY Supporter
Winnipeg
Has anyone used a Maida-ish design to regulate B+ for a tube mic's power supply?
I want to be able to order a batch of PCBs and then transformers from a single source and be able to use them on any tube mic project. I played with some different B+ voltages and loads (100VDC - 220VDC) with passive filtering and with a Maida regulator. The Maida adds some parts cost, but it's easy to get 100 to 220 from the same transformer.
In other words, I could buy multiple transformers like this one, without knowing what project requirements would be:
https://sklep.toroidy.pl/en_US/p/TSTA-0015001-Mains-transformer-for-tubes/632
Same transformer and same PCB for multiple different projects with a few different components.
Started thinking of this after reading the @rock soderstrom thread with an already quite versatile PSU design:
https://groupdiy.com/threads/diy-pr...ps-like-preamps-buffers-or-microphones.84324/
Passive (for B+, regulate heater) might be the smartest way to go, but I do like the idea of using the same transformer for all future projects.
Awesome. This is a lot simpler than the Maida, and I'd still achieve the wide range of loads from the same transformer. I really gotta start paying more attention to the Drawing Board.
I always wanted to build this circuit and merge it with my doubler heater-PSU linked above and then compare it directly in a microphone or preamp.
Here is my first draft for a PCB, what do you think? Sorry for the rough sketch. Diodes are UF4007, most electrolytic capacitors are 33uF/450V because I have a lot of them. I would like to install the LED as drawn, any cons?
How many dB ripple rejection would such a circuit have? We need Ian (@ruffrecords), I still can't work it out 😅
R1,R2 = 1K for 10mA total current
