Reissmann-Neumann Tube Mic
tardishead
Sussex, UK
anybody know anything about these mics? Reissmann-Neumann Tube Mic?
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=7315087315
I was going to get this until the seller told me that it needed a 3 pin DIN connector to connect the mic to the PSU.
not many pins heh? no output transformer? does not look like many parts at all - is it poss that most of the guts( output transformer etc) are inside the PSU. surely sending the high Z signal unbalanced is going to have severe problems
hmmm lets see from the info posted with the ebay sale.
It has a neumann M 55K capsule wich according to google sites is an OMNI cirectional capsule. So it's an Omni tube Mic. Aside from that the shape gives it away.
I don't speak German but looking at the numbers Has A frequency responce of 30HZ - 20K
Looks like they are saying it has similar characteristics to a neumann CMV 563. Has 2 din connectors on one side of the power supply and on the other has that 1/4 Jack which thows me. Looks like it goes to the mic with a cable but that would be wrong in a tube mic. Looks like a power switch and a 12 amp fuse in it. I am thrown by the 2 din connectors mainly because there are 2 I Would say that one is for the mic to PSU and then to a console but the bottom pic of the mic looks like 1/4 connector? it if anything should be a DIN. Hmmm 2 Dins possible it was a broadcast mic and was used in german broadcast as back in the day they would use din connectors VS the now standard of XLR. I have never seen the neumann logo on the bottom B4 but that doesn't say much as I am no nuemann expert.
I hope that helps some.
I guess the assumed 1/4-jack is a banana-jack for external grounding. The sign next to the jack shows a sign that is commonly uses for 'Ground'.
I doubt the thing with 3-pin-connector. You need one for tube-heater, one for tube-anode, one for ground and two for signal. That's five and I think all the DIN-pins need to be used. The sign next to the lower DIN-connector is the sign for 'Microphone'.
But since there is no cable included the function of the thing is doubtful. I would not buy this at this price! Even if it was fully working, I wound't pay that much. You'd better watch out for a real CMV563 with the same capsule (and I'd try to also get a M7-capsule).
Btw. german broadcast didn't use the DIN-connector. They used a large connector known as 'Groß-Tuchel', there were small ones (almost alike DIN) called 'Klein-Tuchel' (like on Neumann KM54, 56 etc.). Good example is the Sennheiser MD421 and MD441: They have three versions: One with Klein-Tuchel, one with Groß-Tuchel and one with XLR. Just as a marginal note...
Chris
Maybe the thing that looks like its a 1/4 socket is really for a captive cable, or something? Also, the DIN connectors shown in the picture are 5 pin, not 3 pin.
The DIN/Tuchel connectors look like 5 pin ones on the PSU. This is consistant with a valve mic with a fixed pattern.
My AKG C60 which was one of the forerunners to the C451 uses the similar connector, however the pins are arranged with a 240 degree angle rather than the 180 degree that this mic uses.
It`s possible that the output transformer is in the PSU (like on my C60), which is not ideal, but does not seem to affect the sound too badly.
thanks for the information. I would say if anything by the mic, gut it and put a g7 in there but it's too expensive
this post made me think of this
http://www.manleylabs.com/containerpages/babymic.html
IIRC Zebra50 worked on some Reissmann microphones.
[quote author="chriss"]the bottom pic of the mic looks like 1/4 connector?[/quote]
It looks like a bottom of the capsule--not the microphone, and of course, needs only two connections.
Interesting. I have worked on 4 Reissmann mics, nnoe of which had a neumann capsule. All the capsules were dirty or damaged in some way, so make sure you get pictures of the cpasule or some guarantee.
Some discussion at this thread
http://www.groupdiy.com/index.php?topic=2185
The geman ebay mic above looks to have the same body as the small mics I saw. These also had 5 pin DIN type connectors. If so it is likely/ possible they have a similar circuit. It will probably be something like thos
The mic runs with just B+, ground and heater connections, with the plate resistor and output cap in the power supply. There may or may not be an ouput transformer in the power supply - the ones I saw went straight to another amplifier stage - they were PA mics.
Actually really not so bad! The noise level can be extremely low if everything else is optimised.
Hope that helps. I may be able to answer specific questions.
Cheers!
Stewart
