> are they fast enough?
A good question.
An ideal inductor has an infinite rise time. No real inductor does, and infinite anything gives simulators problems. So I simmed a reasonable perfect inductance with 720 ohms added in series, approximately your relay. The external rise-time (what the diode sees) is not incredibly fast.
I get peak diode current equal to the relay current, peak diode dissipation 0.090 Watts (it approaches but does not reach both 12V and 17mA), and average dissipation like 0.006W for hundreds of clacks per second (faster than the relay, far faster than your finger).
Not fast. In this case, not high current or high voltage.
It would be hard to find a diode which would NOT work.
(Obvious no-go diodes: transisor B-E junction won't block >7V, small vacuum-diode won't pass 17mA at low voltage.)
A good question.
