Phrazemaster
Hi, I have a question about a relay I'm using. I wonder if it matters which way I hook up the current. It's not clear to me from the datasheet if there is a tamping diode; there is just a tiny picture that shows the current direction and no mention of anything else. For the circuit board I am building, it would be a lot easier if the current could flow the other way (just due to spacing/layout). If I'm understanding the datasheet correctly, it's specifying pin 1 hot (+).
Can any eyes better than mine sus out this datasheet and tell if it really matters if I hook it up the way the datasheet shows?
The relay in question is the TQ2-12v, standard relay, digikey part 255-1002-5-ND.
Thanks in advance for any wisdom on this.
Mike
Mike
