Just try 'em all. You should get two sets of +15, -15, +48 or thereabouts. So 6 voltages and two grounds is 8 pins. If there are more pins than that then presumably they're unused and no wire is attached at the mic pre end.hebjam said:Ok, so input ac is fine ( i heated the solder a bit and it read fine). So for the dc on the cable going to the pre, one probe to ground , the other to?
The -38 and -5 should be +45 and +5. Could it be that you're getting probes reversed?hebjam said:Ok! So I got +18.2(2), -18.2(2), +45, -38.4, and then another two which were +5 and -5. So it seems like power might be ok? if so I have to really get to work to figure out why there is no signal
