abbey road d enfer said:
I actually mean stray capacitance between the external armature of the cap and the other parts of the circuit.
The MKT series is polyester, which comes as the worst choice for film caps, only slightly better than electrolytics.
Check the articles by Walt Jung and also Cyril bateman.
I've read both some time ago, i refreshed some today
According to the Bateman articles:
#5
"From these 1 volt tests the best 1 mF electrolytic, the Bi-polar type, was clearly beaten by the good metallised PET"
#6
"10mF choice
We have three possibilities. A double Bi-polar using two 22mF 50/63 volt Bi-polar electrolytics, a 10 mF metallised PET or an assembly of three 3.3mF PPS capacitors.
The lowest cost solution for use with signal voltages less than 1 volt and no significant bias, is a double Bi-polar series pair.
A 10 mF MMK metallised PET takes the same PCB area and distorts less with DC bias.
The PPS capacitor assembly ensures lower distortion, especially when used with increased AC signals or DC bias voltage.
However it occupies more board area and is expensive.
An assembly of Polypropylene capacitors, as used in the DC bias network, would provide the lowest possible distortion but
requires a five times larger board area and is most expensive.
For small AC signals and modest DC bias, I choose the 10mF MMK metallised PET capacitor"
Interesting article is also here:
http://sound.westhost.com/articles/capacitors.htm
Of course in my equipment are different conditions, change from much higher value electrolytic to the lower MKT etc.
Tests should give me some light
In microphone circuits for example: Audix CX112 and AKG C414, change of output tantalum for identical value MKT gave realy audible difference which i didn't suspect at all.
In cheap, moded, four channel preamp also. 10uF electrolytic vs 4.7uF MKT.
My friend did blind test, with two channels with MKT vs two with electrolytics (which one have "premium" e-cap inside).
He choosed both with MKT inside as better and both with electrolytics as sounded worse and the same.
I did some other recapping on different gear, in some were audible effects in some completely not
Of course it would be better to use polypropylene, but here "size matters"
What do you think about parallelling polyester cap with lower value polypropylene?
I didn't notice improvement in bypassing electrolytic with film cap, but maybe i haven't done too much configurations like that.
