Some people talk about it like it's a thing. Tried it once, and can't say it actually made a difference for the better. Possibly worse.
As in M49 / U67?it depends on the geometry of the mesh. if the basket is well-designed already, this won't do anything
well, it's wrong to say it won't do anything, but if they paid attention, it's part of the response to the microphone or the basket has no serious standing wave issue in the first place, so messing with it may negatively alter the sound profile or do nothing. it's only in mics that have wire that's too thick, and with a high-mass inner weave, that removing the inner layer will result in a less pronounced standing wave.As in M49 / U67?
i haven't. i'd love to see pictures of what you're talking aboutAs an aside - have you ever taken an AKG Blue Line capsule apart? There's mesh in front of the diaphragm that's so fine and dense, that it lets no light through. How can that work? The one I disassembled was an omni; I don't know if the other capsules are different.
how close was itI didn't take any pics (it was many years ago); but I literally couldn't believe my eyes.
Same with AKG CK62 capsules (for C460B/C480B) There‘s two versions, ULS (near field) and DF (diffuse field, discontinued long ago), only difference was the mesh. The ULS has a really dense ‚disc‘ in front, i should have one or two after converting a pair to DF. Will look after and take picturesi haven't. i'd love to see pictures of what you're talking about
The other sonic hindrance being the resonator disk. The removal of which proved to be too delicate of an operation. Unsoldering the front wire released a fury of built-up tension that spared nothing in it's path.
the real k47 has a presence peak here too. even first party k47s are up at least 2dB at 4k. The highest I've seen on a brand-new all-original capsule was 5dB. It sounded like it had a telephone effect on it. This is just how the capsule sounds.Nothing like shiny brass for a good placebo affect. Which brings us to our last and final upgrade. The 4 khz peak of our lovely u47-inspired capsule (straight from the Republic of China) :
This is just a rant at this point, but of all places for a presence peak. After the above-pictured adjustment, my modifications were complete, and Aspen Pittman's legacy fully-restored.
Who actually does an EQ sweep, stops at 4 khz and says "Perfect" ???
End of rant.
"Fury of built-up tension"? Is that solder on the diaphragm?
That's actually how the wire connects, weirdly enough.
The wire was awkwardly positioned, creating some tension. After it was freed, my tweasers weren't gripped firm enough to hold it, so the end of the wire landed on the good part of the diaphragm, tearing through it. Not like I was actually going to use the capsule for anything, but still.
Oh, dang
Note to self - cut the wire first, next time(?)...
