Repair: Akai MFC42 schematics needed
Script
Japan
Anyone has the service manual and/or schematics of the Akai MFC42 filter module and can share? Either via PM or, even better, in the Technical Documents section :)
Found the user manual, which I have to read first, cos I'm not sure what this unit is supposed to do in the first place.
Just in case you’ve hung on to the Akai MFC-42, it appears the schematic surfaced at some point:
MFC-42 Service Manual (parts list really)
https://www.vintagesynthparts.com/wp-content/uploads/2018/01/MFC-42_SM.pdf
MFC-42 Schematic
https://www.vintagesynthparts.com/wp-content/uploads/2018/01/MFC-42_SCH.pdf
(Schematic text is hard to read but maybe it can be cross referenced with the parts list)
Thanks for the schematics.
I had found the Service Manual at some point and remember having opened the unit to take a look.
But the stacked PCBs and a possibly damaged and probably difficult to source SSM ic were a bit disheartening at the time.
Unit is still somewhere under a huge pile of other stuff. Will take a look ;)
