cpsmusic
Hi Folks,
About a year ago I picked up a Roland SRV-330. It was working well until a couple of weeks ago when I noticed that the LCD had started to flicker. I opened the unit up and of course the problem resolved itself. Now, after putting the unit back in a rack the LCD has gone blank. Note that it's still lighting up (i.e. there's a noticeable difference between when the unit is on and off) but there's no text visible.
I've opened the unit up again and had a look at the power supply, hoping to find a swollen cap or something obvious, however it all looks fine.
I've checked the output of the power supply and it's outputting the right voltages - +5V and +/-15V.
Next thing I checked was the voltage going to the LCD and it's 4.7V (it's supposed to be 5V). Would that be enough of a drop to cause the LCD to not work is the way described?
Any thoughts as to what else could be going on?
Chris
Chris
