Replacing GOhm resistors with diodes, the theory behind it
MicUlli
Germany
Hello All,
after finishing some experiments successfully i want to share the results. I replaced a 1GOhm resistor by a double diode and found the noise floor getting down considerably. Find attached a document i created to explain how it works..
  • Diode_statt_GOhmWiderstand.pdf
    176.6 KB
Works well enough for parts like 2SK596 (with built-in diodes between gate and source)...
As the resistors are usually mounted ‘hovering’ above the PCB, does SMD (and possibly the very high effective resistance) have practical implications when connecting the diodes?
I've always wondered about similar problems with all the SMD OPA164x solutions replacing a JFET.
Fitting the Hi Z input of an SMD OPA1641 op-amp onto stripboard posed an interesting challenge! ...
I kept the connection between the 1G resistor and the input to the op-amp 'offboard' by not fitting relevant adaptor pin, and mounting the op-amp and resistor as in the attached photo. Seems to work pretty well....
    152.1 KB
Hello All,
Sorry, somehow i missed that you mentioned this in the document.
The problem occurs when these start conducting. I measured output of some LDC with a simple opamp unity gain impedance converter, and these can put out 12V peak to peak! At plosives, snare hit and such. You can get away with small capsules.
Take a look at this video, the part about the diodes starts at 8min. Doug decided to bootstrap them.
That does seem to leave at least some connection through the adapter PCB with the plastics below to the main PCB/stripboard, but I guess it’s probably good enough. In the video above, the diode package seems to be mounted completely on the PCB.
I would always recommend the connection between JFET gate and GOhm resistor (or diode) and capsule wire soldered in free air (no contact on pcb). A datasheet from TI (LMC6001) gives useful hints, see attachment ;)
  • lmc6001.pdf
    717.6 KB
I think the very proximity of the pins to each other on SMD devices are probably more of a concern than the impedance of the plastic?.....
Might be worth trying to lift the pin as you would on a thru hole op-amp ? ... (as shown on fig.29 of the data sheet linked to by MicUlli in post #10 ).
So far (I only have mics constructed within the last 2 years to refer to) I have had no problems with the construction I showed.
It is important to ensure ALL the flux on the adaptor is removed with isopropol alcohol.
(Cleaned after the 1G resistor and capsule lead are soldered of course)
Look for the AT patents
IIRC diode use was posted about in an old thread about the AT4060
Certainly NOT 1N4148 as they have a high Leak Current and are rather Noisy.
Most Schottky Diodes as the BAT series are WAY better (but not all of them) .....
I have no experience with BAT199 - Nor this circuit ....
