Mbira said:
yes-I'm trying to understand the physical difference that happen with and without a resistor.
Define "without a resistor".
Are you talking an open circuit or a short circuit?
Both quite OPPOSITE situations can be described as "without a resistor".
There IS less current flowing with a resistor vs without a resistor. Right?
See above.
This is because the resistor is slowing down the speed that the electrons are able to get through the wire. Right?
WRONG.
And we already answered that.
To keep things simple, I am just thinking of a battery with a resistor between + and -
Ok, then current will flow from positive terminal to negative.
Actual electrons will frlow from negative terminaltopositive.
No speed slowing is involved, at all. <-- remember this.
If by "without a resistor" you mean a dead short, just a piece of wire, yes, through a short current will be
infinite, so any other current will be less than infinite.
This is because
Right?
No, No, No, read the answers, please.
You won´t make wrong Physics right just by insisting, it does not work that way.
From the negative terminal, the electrons can "see" that there are physical things (atoms and molecules?) that are in the resistor that is up ahead and so because of that resistance, only a certain number of electrons per second will be able to pass through that physical limitation and you can only have one electron leave the negative terminal for every electron that returns to the positive terminal, so that is the reason that there is less current when there is a resistor vs without.
Painting with a very wide brush: "yes" , "sort of" , "wouldn´t use those words", etc.
It can be and is explained way simpler, without delving into sub-atomic Physics and such:
* you have a battery which supplies "X" Volts.
* you connect a resistor across those terminals.
What is a resistor? : a device, a "thingie" if you wish, which shows a measurable and very real property called "resistance".
Why/how/when/who/what?
Well, you don´t *really* need to know that to happily design Electronic circuits.
IF so inclined, fine with me, your local Library is chock full of Physics books to help you, not something which can (satisfactorily) explained and even less understood with a couple Forum questions.
Start reading and go as deep as you wish, you are welcome.
* when you connect that resistor as stated above, current will flow through it.
How much? : I=V/R ... just do the Math.
What if I vary V or R ?
Result will change.
You can even calculate current if R is infinite (open circuit) or zero (short circuit).
Go ahead, do it.
And of course use various V and R values.
Why are you wasting your time trying to tell someone what they shouldn't spend their time learning?
HEY!!! WHO SAID THAT !!!!!
You are being told to STUDY, and do it the RIGHT WAY.
How many times do I need to say that I'm interested in learning about this REGARDLESS of whether it applies to circuit design.
Then you are in the wrong Forum.
Try a Physics dedicated one instead.
Why do you care so much about trying to tell me what I SHOULDN'T learn?
Why are you asking then?
Please don't tell me what I should and shouldn't be concerned with learning, and then maybe the next guy won't waste his time trying to tell you what you should be spending your time doing.
If my questions are irrelevant enough to this board, then I assume that John or another mod will tell me to stop.
That´s not the Moderator function.
Until that happens, if what I'm trying to learn about doesn't interest you or seems irrelevant, then why discourage someone else who is interested in it?
You are encouraged to do it the right way.
If you insist on doing it wrong, it´s your problem and it will lead you nowhere.
In a nutshell: you have been *politely* answered by knowledgeable Members, *all* answers were relevant and to the point ... hope someday you can get something useful out of them.
And the Library visit invitation is still standing
