Matador
I have a Reverend Hellhound guitar amp that I can't seem to locate a strong 120Hz buzz signature. This one has me stumped.
Annotated schematic attached (for the Reverend Kingsnake, which is almost identical except for some power stage changes which aren't relevant here): the amp was damaged during shipping, so I had to replace the power transformer, all of the tubes, and rebuild the power supply PCB due to a crack. Then, starting at the output, I worked my way back through the circuit trying to isolate where the buzz was coming from:
1) When I plug into the return jack and inject a signal there, the amp is quiet, loud, and sounds great. So the buzz isn't coming from the phase inverter or the power section/feedback path.
2) Grounding point A on the schematic and the buzz disappears (this should be the same as using the return jack).
3) Grounding point B on the schematic and the buzz disappears.
4) Grounding point C on the schematic and the buzz disappears (the grid of V2).
So far, so good. Here's where it gets interesting.
If I pull the V4 (reverb) tube completely, the buzz remains. I also hard ground point D (the reverb level/mix) and the buzz remains. I think this eliminates the reverb send/return from the equation.
Leaving V4 out and leaving point D grounded, if I hard ground point E, the buzz remains. The only different between hard grounding point E and point C at this point is Rb, the 470K mix resistor.
I removed this resistor and tested it, and it measures 477K and appears normal. I also replaced it with a known good 470K just to be sure. However if I leave points E and D grounded, I still get a loud 120Hz buzz signature through the amp if Rb is in the PCB.
This mystifies me. Somehow Rb is developing a noise across it with zero signal flowing through it, and I can't isolate it any further. If I pull Rb completely, and inject a test signal into the 'right' terminal of the resistor, I get a clear, loud test tone with no background buzz (this is the same as driving a signal directly into V2).
At this point I must have missed something incredibly obvious....
