FYA,This schematic is not correct it won't work.First tube needs external bias,(from heater) the second amplifier tube the cathode bias is ok.Hey Matt!
I have schematic from Andreas Grosser, even newer version than this online.
It's really interesting circuit, but first i want to make something close to the original with some mods.
PSU of course will be in the outside box and filament voltage will be regulated.
After you replied i looked on Andreas schematic, and he also put higher grid resistor on the second stage, so probably you are right, that the main problem is the Miller capacitance.
Replacing 30k/100k divider with 100k/100k polarisation voltage should be less than 70V. It is a good value for the start, then i will empirically choose the best value for my ears
For now i want to make something like in attached schematic.
Any comments appreciated
