For Sale RFZ MV810/2 mic pre **price reduced
ravachol
Ireland
Hard to find these days—the word is out. This unit is sounding sweet but the switches will need some maintenance. Tthe pad switch is very stiff; the gain switch turns freely but doesn’t actually progress the mechanism.
You’ll need a -24V power supply, rated 1A or so. Other than all that, it’s good to go.
€660
Correction: the gain switch mechanism does activate but you have to pull on the switch slightly to have it engage.
Also note: part of the issue with the pad switch is with the screw tension on the knob: the screw is jammed.
