Skiroy
Okay guys I have a 1975 4 pin suitcase rhodes. It is 100W and 4 speaker version so Im not sure if it is the peterson or not but both left and right power amps use 2 Delco GM 120725 Transistors.
The thing is the left side has the writing in Green and the bottom number says"7539", which I am guessing is the batch number or something. But the right set is in red writing and the bottom number is " 7515".
So how can you tell if they are Germanium or Silicon?
The reason I am asking is because the Green ones stay cool while the red ones get really hot. I am also getting intermittent distortion when I hit the keys harder at times and the distortion is alot more frequent through the head phones vs through the speakers.
I ruled out the power supply because I swapped the power connectors and RCAs and the power amp with the red writing still gets hot. Also when I disconnect the preamp and run straight off the harp to the power amps they dont get hot. But if it was a problem with the preamp on one side I would think when I swapped the power connectors and RCAs to the Power amps the other power amp with the green transistors would get hot. Also I checked the resistor on the power amp boards and they both have the same values for all resistors.
I tested the green for shorting and it doesnt seem to be shorted. But when on the multimeter setting to test for shorts it reads 67(which I dont know what this reading is because I have been told too many things from current,to beat,to ohms) but the the resistance does measure 68ohms. Also a note is I can only get a reading for a short or resistance when the positive probe is on the transistor's leg marked "E" and the Neg probe is on the leg marked "B".
Now the Red transistor is weird. It wasnt reading as shorted and the resistance changes every time I test it. It was at 96, then 67 and now its at 61. It didnt beep(indicating a short) but now it is and the reading on the multimeters short position says 79. This is why I am confused of this value because the other transistors reading on this position and ohms were very close but now here they are not.
So here are my questions.
1. Are these red transistors bad because of the reading and is it normal for them to get this hot?
2. How do I tell if they are silicon or germanium because why would the other be written in green that stay cool? And if the greens are germanium and I have to change the red ones to silicon will the Left and Right sides sound different?
3. The power amps on this rhodes have a adjustable pot like on the the power supply. Is this used to set bias on these as opposed to having to soldier in addition resistors? And could this be my heat problem?
4. If this pot is for bias or even if I have to do it the old school way where am I measuring voltage while setting the bias? What terminals,wires ect?
Thankx,
Colin
Thankx,
Colin
