Marik said:
I'd love to get those measurements. Pri. and sec. inductances and DCR (do you have a bridge to measure the pri?), as well as ratio (important). What core it uses? Can you tell material?
BTW, in Microphone Engineering Handbook there is a chapter by Peter Baxandall about step up (from 30 Ohm) transformer for the 4038. From memory, I think it is done on EI24-25.
I don't have a bridge to measure the primary. Maybe I could make my own bridge with some copper wire as resistors and then send that length of wire for measurement by you.
Otherwise, L, R and ratio shouldn't be too difficult when I get time.
Transformer is toroidal with a permalloy core. It is in a mumetal case for shielding.
